If installing an aftermarket air filter you’ll have to open up the main jet. Turn the fuel valve off and remove the carburetor bowl with a 10 mm wrench. Gas will begin to leak when you loosen the bolt so have some paper towels ready. Remove the bowl it seals on an o-ring. Get the proper sized flat blade screwdriver to go up inside the carburetor body and remove the main jet the emulsion tube will come out with it.
