DIY....re-jetting a 6.5
If installing an aftermarket air filter you’ll have to open up the main jet. Turn the fuel valve off and remove the carburetor bowl with a 10 mm wrench. Gas will begin to leak when you loosen the bolt so have some paper towels ready. Remove the bowl it seals on an o-ring. Get the proper sized flat blade screwdriver to go up inside the carburetor body and remove the main jet the emulsion tube will come out with it.
it should take about 5 minutes :thumbsup:
I do knot that CA has a different part number on their motors. Maybe it is loctite in place. I think your best bet is to just buy a used carb
