build.
  1. Merkle
    Merkle's Hot Rod DB30 Build.
    After getting hooked on the world of small two wheeled things, I decided it's time to build up a seriously fun, and cool looking mini bike for myself. For those who were at the Alabama meet up in September, I had the bone stock 97cc Baja Viper, well that bike has been sold, at a $20 PROFIT I...
  2. Monte88
    Briggs Intek Build.
    Looking for opinions on a build. I have a 6.5 Briggs Intek engine that will be going in my minibike. The bike will be used for 100ft drag racing, and little else other than some putting around the yard. Right now, there is no carburetor, and the only modifications are a short straight-pipe...
  3. C
    first build. pictures and some questions.
    so decided to try my first build. got an old frame off craigslist and di a ton of research before figuring out how the whol rear axle worked and all that jazz. anywho. went easy since its my first. 212cc predator engine with upgraded exhaust, air filter and jets. and a handful of OldMiniBikes parts to...
  4. Hreagle
    Boonie Build.
    I should have posted some Pics while I was building this And here is the (almost) finished project. I have a couple of small changes in mind. I started this in the fall and just test rode it yesterday. 5.5 HP Tecumseh Snow King engine with lighting coils. Added a new/old 12V starter for an...
  5. Jakespeed63
    FNG Silver Streak Custom build. Frame I.D.???
    Hey Fellas, Found this crazy forum, through a guy on The HAMB message board. Thanks for having me. Got this little scooter, a million years ago, as a toy for my girls and nephews. Rescued it from the corner of his garage a few years ago. Finally making serious headway towards a finished product...
  6. Docdc
    Fox Doodlebug Build.
    This is my second mini bike build and this one is for my oldest daughter. I fell in love with the Foxes with this bike and hopefully there will be one or two more in the future. This bike had a lot of problems and one of them was the sprocket. Not only was it worn out but is was badly beaten up...
  7. R
    New Build.
    Started this build this week, not sure on what the frame is. Anyone happen to know? 10'' wheels.... just picked up new 3.50x10 rubber today. It's getting a Tecumseh HM-80. I ordered up wheel bearings, jack shaft kit and a rear axle from OldMiniBikes, hopefully they'll be here tomorrow. rough mock...
  8. S
    Need some help for an ARCO build.
    Rescued an early 70's ARCO from the scrap heap. It's my first build and looking for some help and suggestions. What would be a good engine in the 8hp range? Also, if I were to go to Tractor supply and just buy an off the shelf engine how do I modify the throttle to work with a cable? Also...
  9. Belbuekus
    My little Hornet build.
    Well I got it broken down and even spent a little time getting some of it blasted and primed.
  10. Dragbikemini
    Newbie getting in with a Bad Dog build.
    Bad Dog must think I'm Bad too because it comes with NO directions!
  11. cheezy1
    Yep..big surprise..another Ruttman build. lol
    This was a Spyder that I picked up from another member on the forum. Roccosbike was nice enough to ship it to me so I could begin the process:bowdown:. It was a very clean roller to start with. I am still kinda torn whether or not to put and original HS-40 on it..or go with the new look. I guess...
  12. minibikedude
    Any ATC70 guys on here! Custom ATC70 build.
    I thought I would share this on here. I now some of the members also have ATC's. I been reading this builds on 3wheelerworlds.com. I,m impressed with this guys build. It's really neat to see what guys do to these ATC70's. Here is the link on the rest of the build. bw80 to atc70...
  13. Solo Cali
    My 200/240 build.
    Worked all day trying to get this motor done. Was real close until I noticed a crack on the inside oring groove. Thats what was hitting the piston at TDC. Have a feeling the receiver groove on the block was not big enough for the size wire that was being used. Back to the machine shop first...
  14. mhornfeck72205
    chopped up quad kart build. :-)
    So after an incomplete build on my last go kart, and having found a quad frame and 250cc engine for $80, I chopped up the quad, put a riding mower seat in the middle, bent down the steering, threw an engine plate on, and now I'm up to something rideable, but theres stuff I still need to finish...
  15. K
    NZ Tru-test project build.
    Hello. I brought this bike about mid way through last year off a guy at work. The original plan was to build it up original but the more I looked at it the more I found wrong. At some point the rear wheel has been changed to a drum brake and in the process they have gas axed the drop out off...
  16. GTLabs
    My mild E85 alcohol build.
    I did my first burnout today with Dr. Greenthumb:punk: That was effin' cool! I also ran into some of the same issues that I ran into on my Scooby and in other applications: An almost complete lack of suitable heat in the engine block! I'll noodle with this stocker some more with plugs and...
  17. S
    New guy. My brief build.
    Picked it up out of a shed. Owner said "Take it". I stared at it for a while and reluctantly toosed it in my truck. I spent a weekend on it. Glad I got it,
