bushings
  1. P
    New reproduction Speedway fork neck bushings
    #S10198 SPEEDWAY FORK NECK BUSHINGS 5/8" ID. 1-3/8" OD. 1970-71 ALL & 1972 SABRE. REPRO. PAIR $15.00 Oak Grove MN.
  2. R
    MB-200-GC handlebar bushings
    I just purchased an MB-200-GC to putt around on and it is in rough shape. One of the biggest issues I have with it is the factory handlebar mounts are missing the rubber bushings and the handlebars are extremely wobbly. I can't find them anywhere online. Can anyone help me either locate some...
  3. danford1
    Triple tree fork tube nylon sleeve bushings.
    Some Minibikes have a nylon bushing sleeve inside the bigger diameter tube for the smaller diameter tube to slide in. A lot do have any bushings. It is just one steel tube sliding in another steel tube. Those are sloppy fits. It is most likely a 7/8" tube inside a 1" tube. Who sells the nylon...
  4. james ackerman
    Repro gilson, wards, neck bushings.
    Someone wanted to buy my gilson frame ( can't remember who now) then someone just wanted to buy the bushings so I decided to have a few sets of reproduction bushings made. I have one set left, they cost me $20 to have made. I'm asking $28 shipped for the set. I'm not trying to get rich just...
  5. C
    WTB- Gilson Bushings
    Pair of 0.75" ID, oval OD bushings needed.
  6. T
    Bearkat Twister motor mount bushings?
    I am starting a restore project, I need to replace the rubber bushings connecting the motor plate to the frame. Does anybody know of a website or seller that carries these? I figure they must be a automotive leaf spring shackle bushing, but for what vehicle? TIA
  7. ludicrous speed
    bird bike neck/headset bushings?
    i am building a bird bike/golden pinto?,for a local couple for their 9 year old daughter. when i took the forks off i noticed the bushings? inserts? in the frame headtube are worn out and need to be replaced. where can i find these? also,the bike was id as a golden pinto awhile back but...
  8. M
    '67 Continental- steering fork bushings
    Any tips or secrets to removing the fork bushings on my '67 Rupp Continental? I don't want to bugger something up that is hard or impossible to fix. I've soaked them with PB Blaster, but they are not budging. Just get a bigger hammer? And...if I get that far, any tips on re-installing the...
  9. C
    Rupp Roadster2 shock bushings?
    I can buy a whole complete new set for around $45.00 shipped....has anybody found a cheaper idea....I thought about taking industrial rubber hose and cut small pieces? some kind of rubber bushing from a hardware store?
  10. Fox Brake Caliper and Mounting Hardware.
    Fox Brake Caliper and Mounting Hardware with Flanged bushings for flotation.
  11. R
    H25 crankshaft bushings
    I have an h25-25188g motor and unless I can find another similar motor I am planning on doing a rebuild. My question is that should I replace the crankshaft bushings and what are the tolerances of these bushings? It appears that they are not being produced anymore and would much rather reuse...
  12. minikenny
    Removing neck bushings
    I'm trying to remove neck bushings from an Bonanza BC frame. I thought I could tap,tap,tap from opposite end with a long screwdriver and get them out. No dice. :hammer: Even tried a few whacks. Tried propane torch heat on the neck, along with whack,whack, whack :hammer:. That was probably...
  13. massacre
    ARCO Head Tube Bushings
    Hello, I need some ARCO head tube bushings bad. Will pay good money thanks! These seem like steel but would prefer bronze but will take whatever I can get at this point lol 5/8" ID X .965" OD X 3/4" long Flange = 5/64" thick, 1-1/8" diameter Thanks for any info anyone could provide...
  14. massacre
    Head Tube Bushings ARCO
    Hello, I have an ARCO that has bad bushings in the head tube. The forks have a little shimmy in them, and when I removed the fork bolt (brand new) it was worn all funny on one end of the fork bolt. Does anyone have a source for new bushings? They seem to be bronze. Thanks for any info you...
  15. D
    Bonanza BC 1300 neck bushings
    I am just about to paint my hodaka BC 1300sh project. Only problem is that I can't get the old neck bushings out. I have already ruined good parts because I didn't know what I was doing. I don't want to mess up the frame. Any suggestions? Thanks in advance!!! Derek
  16. Dragbikemini
    Nylon bushings
    Nylon bushings that I pulled from a set of pressure washer wheels. Tossed them in draw thinking I would use them for something. Can you use them? 5/8 x 1 1/4. Thinking this is a trade item One mans junk another mans treasure. If you need these reach out.
  17. J
    can't identify
    GOT THIS YESTERDAY HAVE LOOK ED TIL MY EYES HURT TRYING TO FIND ORIGIN. HAVE FORKS TOO NO MARKS OR STAMPS #ETCHED forward pegs piping on seat single loop top rail 5/8 axles scrub brake frame out of 1 inch tubing has general safety-rib 2 ply nylon 2.80/2.50-4 tires on it seems to have...
  18. Not so mini bike
    Roper guys
    I've seen a bunch of roper builds on here and was wondering where you guys got the bushings for the forks and neck tube. I believe they are 3/4" by 5/8".
  19. O
    Axle tube/bushings
    Good day all, With a lack of metal shops to purchase from locally I have to order parts required for my build. So what I am in need of is some input as to what size pipe and bushings are needed for the job. I plan on using 5/8" axles and would like to use brass bushings because I would like to...
  20. bikerboybenny8
    George Barris Custom
    Hey yall!! finally decided to get something going after sittin around for a bit... I picked up this George Barris bike in midwest pa a few weeks ago and it was trashed.. anyways after some cleaning i got most of the gunk and grime off of it. I picked up a 212 Predator Clone at HF and took all...
