carb?
  1. CarPlayLB
    Fuel pump with Hs50 carb?
    I am planning on using an Hs50 carb on my Briggs 5HP. I have done the billet upgrades. Due to the fact that nothing I build is easy or conventional, I will need a pump to get fuel to the carb. I am using a Walbro pulse pump. Will the needle and seat have sufficient ability to handle the...
  2. buckeye
    What am I missing on carb?
    This is my favorite Briggs engine. The only issue I have, the screw that holds the choke to the carb body gets loose and I am afraid I am going to loose it. I tighten it as tight as I can. To the point that you can barely engage the choke. The issue is, as soon as I close the choke, the...
  3. B
    Briggs 3.5 HP carb?
    Hey everyone I'm new to the forum. Can anyone tell what carb I can use with this motor that would bring out the best of it. I have one picked out. Can anyone confirm if I'm getting the right setup. Thanks everyone Monster Scooter Parts: 50cc, 70cc, 90cc, 110cc, 125cc "Honda Style" Carburetor...
  4. T
    DB30 2.5 carb?
    I have had enough of the cheap Chinese carbs. Any suggestions on which quality carb I can purchase for the 2.5 hp motor?
  5. markus
    tecumseh late model primer bowl carb?
    I picked up a Sears labeled Tec the other day in a bike/parts buy. its a side popper 3 or 3.5 have not checked the numbers yet. its got one of those primer bulb bowl carbs on it, of course the bulb is rotted and gone. Normally I have no use for something like this but since period correct...
  6. Beal
    Identify this carb?
    So there I was cleaning up this carb, and ofcourse I lost a part. A piece where the needle valve seats. :doah: I have no Idea what engine it is from. oh, and dont let the manifold fool you, its from a Tec. Thanks.
  7. M
    Tillotson 314e carb?
    Is this a gas carb? Can it be modified for alky?
  8. Cornishrooster
    H50 with 22 mikuni carb?
    So my 22mm mikuni carb and intake off the predator matched up perfectly to my h50. Is there any reason why this wouldn't work? The governor is still in the engine but the linkage doesn't attach to the new mikuni carb. Does the governor pin need to have tension on it? I tried searching for...
  9. Stephen115
    GX390 carb or 22mm Mikuni Carb?
    It's time for a bigger carburetor and I'm stuck between these two. Mods: 5.5hp clone - gx160 filter adapter billet rod header valves lapped gov. removal .265 cam bigger jet I'm currently running E85 The gx390's are around $20 and the Mikuni's are $42 Could I get some pros and cons on these...
  10. jon321
    Can someone hook a brother up with a float pin off a 1970 ct 70 carb?
    In the midst of rebuilding my carb I lost the pin, it looks like this. Thanks let me know what you want for one..
  11. M
    Mystery hole in side of Briggs 5HP carb?
    Hi all, I am new here, just picked up a rust bucket go kart for my son with a non-running Briggs 5HP motor. While I know it is not a mini bike, Google sent me here a lot when trying to find answers about this motor, so I figured y'all were the guys to ask! I am slowly working through...
  12. Rapidrob
    How to adjust H30 carb?
    I just cleaned the Carb and have some questions. I counted the turns of the two needle valves and replaced them where they were for a try. The engine will only run for a few seconds then will not start again. Spark plug gets wet. Where should I set the two valves to start the engine. I know I...
  13. B
    OEM or new replacement carb?
    I need to replace the carburator on my HM80. I think I have found a new OEM for much $$$ but see that replacement carbs are available from OldMiniBikes Warehouse for a lot less. Would OEM be worth the difference? The new OEM is over double in price. Or should I try to rebuild mine first...
  14. trailramdan
    throttal cable hook up on this carb?
    just got this today and ive never dealt with these before either..awhile back i ordered a new cable from OldMiniBikes warehouse and from what ive read i wont be able to use it!!! so any tips and how to's on getting the throttle hooked up?
  15. gixxer20071
    '71 rupp scrambler carb?
    Could someone post a picture of a '71 rupp scrambler original carburetor? I want to make sure I have the correct one. Thanks
  16. rdog348
    Tecumseh Adjustable Carb?
    I need an adjustable carb to fit my Tecumseh Power-sport.
  17. creia
    Taco minibkes- What type of carb?
    To you Taco experts out there: On the models that came with Briggs engines, were they all the "Pulsa-Jet" (diaphram-type) carbs? Did any originally come with the "Flo-Jet" (float bowl-type) carbs? Thank you and regards, Michael
  18. GraveBugger
    any one know where to buy a new briggs and stratton fiver carb?
    well s*** i stripped a thread on my carb, and theres a broken stud poking ount of the other hole, so any one know where i can get a new carb, its the flo jet i think, the one that mounts on the tank
  19. Sprocket86
    Rejet fixed jet carb?
    Hi to all. I am in the process of finding a carb for my 1976 HS50 tecumseh engine. I had a 2004 H35 powersport tecumseh carb that I would like to use. The problem being is that carb is a fixed jet carb and set lean from the factory so it barely runs the 5 hp engine. My question is can you jet...
  20. danc9
    3 hp Briggs carb?
    Got this one on one of the 3 hp engines I picked up this past week. Dumped a little gas in it and it fired right up. It's not in any of my parts schematics, so what is it? DAN
