How do you remove these freewheel hubs from the rear wheel? I want to get a non spinning hub on here. Seems like it would thread off but then im thinking i need a special tool?
I am in need of a 4 bolt front wheel hub with 2 inch spacing for a steel two piece wheel. I am not picky if it's new or used and it doesn't need to have bearings, just the mount is okay. Thanks for the help!
Hi members i am looking for a brake hub for a 1969 rupp scrambler just like the one in the photos if any one out there could help you would be greatly appreciated as you can see in the photos mine is broken.
i have a mini bike :scooter:that i bought years ago and painted the bike and when it broke, i couldn't find any parts for it and here i am still looking.
:out:
I need to find parts for it and dont have that much of an idea of it i have searched around but cant find anything that will fit.
I...
I am in the middle of a build using an ARCO Bushwacker/Ward's frame-I have a pair of 6.5" pocket bike wheels. They look killer on the minibike frame (at least to me,anyway). I have several questions:
1) Has this been done successfully in the past?
2) Is there a hp limit on the hub/bolt...
Has anybody run a 4" Azusalite for the front wheel? They look cool and are very inexpensive. My only concern is that the hub width is only 1.5 inches. Is that gonna put too much stress on the bearings? I wouldn't run it in the rear, but maybe it's ok for a front?
Does anyone know how the hubs are attached on the Alsport trikes? The setup I have is a 5 on 4 1/2 bolt pattern hub on a differential axle. The end of the hub appears to be fitted with a cap, but I was unable to persuade it to come off if it is a cap. I didn't want to go overboard, just in case...
