I am getting to the point that I need to purchase and install a jackshaft on my Build Off bike. It is a Baja Warrior that Is stretched and has a 420cc Predator going in it. I have a 40 series TC for it and I will need a 3/4 jackshaft.
Do you have any tricks for squaring up all the pieces...
I have an HS40, but the PTO is rusty. Installing the PTO bolt that holds the TC-1 in place is proving difficult; it may need to be re-tapped. The question is how deep is the bolt supposed to go into the shaft? The bolt is about 2 inches long and is threaded the entire length, but is seems to...
Hey does anyone know the best way to figure out where the holes in the blower housing go? You can try just putting the bracket on but then you're not quite sure the tank will sit right.
