Hello evryone, i have a 212 cc predator on my mini bike.... I was wondering what type of after market air filter would fit and how would i install. Would i need and additional parts for the install or can i just buy the kit and put it on?
Guys:
I have a 1970 Rupp Enduro with a torque converter. Ordered the belt from that specific year, apparently that year had a different size than all the others, but my question is what is the easiest way to install a new belt on the bike? Obviously just slip it on the rear, but do I need...
I installed the new arc billet rod last night. Well I am almost done installing. My issue is if I torque the bolts down to 170 in/lbs the motor wont spin, it seems as though the bearings are incorrect as i have to loosen the bolts so the motor spins. I followed the directions measured my...
Ok fairly dumb question.
Which way does a clutch get installed?
Sprocket towards the engine or facing out towards your leg?
I've seen both and facing out seems a little more dangerous than in.
I understand that installation of a Comet Torque Converter can be somewhat cumbersome depending on the engine. What stock engine on the market allows for a no-mod installation? Subaru Robin, Honda GX200, etc.? Advice is appreciated.
Thank you!
David
Hey all !! I am in the process of building my son a mini bike for Xmas. So I bought a 212cc Harbor Freight "Predator" engine. The engine has an on/off switch. My question is...Can you hook up an additional kill switch to it ? I want him to be able to kill it with his thumb as opposed to reaching...
We have a new engine building tool available from Raceseng that will help make installing push rods and rocker arms a breeze! Check out the link below to the Raceseng blog post for more details on our new Raceseng Push Rod Install Tool Now available at www.raceseng.com
Raceseng push rod...
Does anyone have any focused pictures of their installed air filters? And can anyone recommend any good brands for installing air filters to a Honda GX160 clone engine??
I have a used billet rod in good condition sitting next to me as of right now, and no clue as to which way the dipper goes and what to torque the bolts to. So anyone have pics/ specs?
gonna try and put one in. anybody got some horror stories with these? while on the topic of installing looking to advance the flywheel as well. from what i understand when you make the advance there is a small gap between the flywheel and the key like the flywheel should float somewhat...
also does anyone know how to measure the actual size of where to carb would hook up.
one last question could anyone tell me how to hook up the carb or send me a wevsite that explains it thanks :confused::confused:
I have the MB-165 minibaja (196cc) and my TAV2 came in today.. Has anyone installed one of these before? Im not a mechanic por say and i dont want to destroy my machine trying to do something that i shouldnt.. Any advice that you guys can give as far as putting it on and any unlisted things that...
So I am working on installing a billet rod in my Champion clone and it looks like the bolts on the ARC rod are 12pt, 7mm bolts. The instructions call for a 1/4" drive torque wrench (which I have) but finding a 1/4" drive 12 pt 7mm socket is not easy. First of all, am I correct on what I...
So I am in the process of putting back together a Rupp TT-500 that I have resurrected over the past couple of years. The jackshaft brackets were cut off and I have replaced them and repainted the frame. I need some advice on the bearings and jackshaft. I am planning on pressing the bearings in...
Hi Guys,
I bought a Hillard (Masters of Motion) clutch with the bronze sleeve and built in key. When i put it on my HF clone shaft (gear side toward engine), there is about 3/16" space, so with a nut and a washer, the clutch has some play and can move on the shaft. How do you take care of...
