67 bonanza bc 1300s aka "the bruiser"
#25
So here are a few pictures of the build. So as everyone knows the welds defiantly were not the prettiest on these mini bikes. Well at least not on mine… So I decided to clean them up with some JB weld. I think it came out pretty good and I like the clean look it has now! The frame is all primed and waiting some sanding and paint.
buckeye
Become a supporting member.
25 bucks, unlimited pics then.
Bike is looking fantastic. I like the smooth welds. Adds that finished look.
#37
Steel has a tensile strength of at least 20,000 psi. Have you seen slywillie's bonanza's i would not waste his advice!
Im not doubting or wasting anyone's advice. But it is my bike and I'm going to try to do what i want to it. And if it turns out that it cracks horribly Its and easy fix! Thanks for the input.
#38
Looking good. Can't wait to see some color on it. If your spray painting it get a can of the 2k uerathane clearcoat to spray over your base. It's a 2 part spray paint with hardner and makes it look proffesional plus it won't chip. It's like $25 a can. It can be sprayed over any type of base.
fistfullabar
Hope it don't "crack horribly" while you riding! p.s. I know it is your bike cuase if it was mine i would be listening to the good advice i came here for.:thumbsup:
#40
Well if it does crack while I'm riding it there is really no problem other than looks. And like i said easy fix.:wink: Because i did not use the jb weld for structural repair. I use it to kinda smooth everything out and and give it a clean look over the actual welds. I figured it would be a lot stronger than a bondo filler… And i have listened to a lot of advice from this forum thus far.By the way thanks for your great advice!:thumbsup:
