The Doodle Bug chassis with its short wheel base and high center of gravity which is centered over the rear wheel with a rider on it is the reason for the wheelie popping you experience with a Predator 212cc. For example a Baja Warrior bike handles the increased torque of the Predator 212cc with out any issues because of its heavier weight and longer wheel base. Since the concentration of weight and center of gravity is high and near the rear wheel on a Predator equipped DB30 the only way to fix the issue of unintended wheeling is to lower the center of gravity and move it forward towards the front of the bike was to add weight to the bike in front of the engine. I went out and purchased 3 cut pieces of steel each weighing 4 pounds and I placed 8lbs directly over the front wheel bolted on the Number plate bracket attachment on the Badger front fork. The remaining 4lb piece of steel was put down low on the frame just in front of the Predator engine. I attached it by using 3M Body panel adhesive that I had left over to glue the 4lb piece of steel down low on the frame. If you wish you could use a welder to weld it to the frame instead.
I then proceeded to test the bikes stability with the modifications that I made and I found that I could now easily sit on the bike with the kickstand down with out problems. I then took the bike out and proceeded to road test it. I found that the bike has a much reduced tendency to try and pick up it's front wheel when accelerating quickly than it did before. It felt much more stable and I did not have to slide forward on the seat as much or lean forward as much to maintain stability while accelerating. Here are 3 photos showing the steel pieces I added to the bike to improve the stability.
