So I was working on tuning the pz22 carb on my clone build and I went to fire it up last night after making a needle jet adjustment and the thing wouldn't fire. I check that it had spark and noted that it would not start on starting fluid so I immediately though, crap, I sheared my flywheel key (it was a 6 degree advance key). I have an arc billet flywheel on the engine which has probably seen only about an hour of run time and not only did the key shear, but the keyway on the flywheel did as well. I will attach a pic. It is not sheared flat like the keyway, but the wall on that side of the key is drastically reduced. I torqued it to 170 ft/lbs. which is what I thought it was supposed to be. I also had lapped the flywheel so I thought I was set. Anyway, I am wondering if this flywheel is shot or if I can still use it. I have heard of guys who torque down the flywheel real tight and do not even use a key. If I torque it a little extra do you think I can still use it, in order to keep in in place?
