line up the push bolt with the rear oil drain plug drill two 1/4" mount holes in the motor plate and bolt it down with the push bolt retracted then you are ready to go!!
now to adjust your chain just loosen the engine mount bolts a little and screw in the push bolt until the chain is at the tightness you want then tighten down the jam nut on the adjuster body re tighten the engine mount bolts and no amount of chain pull or engine vibration will allow your engine to slide backwards
this is for engines with a rear oil drain plug with a center at about 3/8" from the engine mount plate
you will need 3/4" of motor plate behind the rear oil plug
and air space for the bolt that can stick back as much as 1 3/8 beyond the adjuster when the bolt is fully retracted
it may work on other engines but you may need to shim it higher and use longer mounting bolts
the square Adjuster is $15 shipped in the usa
the Triangle adjuster is $20 shipped in the usa
the style in this picture is not for sale it is only to show how they are mounted
