Please see picture below.
My Harbor Freight motor is eating this gasket alive. Right where cylinder head meets cylinder. You can see the gasket sticking up above the threaded bung in side cover. At first i thought it was me not tightening the side cover down, as i did that once before and sprung a leak on bottom of block. I removed bolts and side cover and they were tight. I thought it was a crappy gasket. So I replaced it again, torqued to 20ft. lbs. red locktite, and it did it again after 5 minutes of test and tune the other night.
My question is this for those who have been dealing with these motors for some time now:
Is this a crankcase pressure issue? (this has happened 2 time now, and in the same place on the side cover gasket)
Is this a casting issue with the block / sidecover?
Is this a balance issue with crankshaft / rotating assembly? (motor does shake pretty good with my setup)
Do I need to change from bolts to studs on the side cover and torque tighter? I am using quality arp bolts now, just wondering if studs would help)
I have a couple more side cover gaskets here, but i would like to know what to do before I use them all up chasing the problem.
Thanks - Kevin
Motor specs:
arc stock length rod and flywheel.
honda flat top piston, rings, wrist pin, clips
honda gx 200 level 4 head from nr-racing ported with single 26lb (will probably change to 55lb soon) springs .065 milled off, 27.5 intake (wanted to keep compression down so i dont have to run race fuel, for now anyways!)
honda .010 head gasket
nr-racing 274 cam
nr-racing 1.3 billet steel rockers
.100 shorter chromoly pushrods
honda gx200 lifters
nr-racing billet guide plate and honda rocker posts
arp side cover and head bolts
tillotson 304wx carb (runs on gasoline)
6* advanced timing
pretty much only thing left that is lifan is the case and crank.
block has not been decked, it has the factory deck height from lifan.
Thanks - Kevin
Motor specs:
nr-racing 274 cam
honda gx200 lifters
6* advanced timing
