I have a Tri-Sport with a Tecumseh engine and a variable belt drive. I believe this power unit is original to the machine. I don't know what model/HP the engine is, but if it matters, I can find out and post it. The center distance between the drive/driven pulleys is 6-1/2". Here are a few pics:
Problem in a nutshell - no 'neutral'. I haven't found a belt that will allow the engine to idle. The drive pulley is the original Comet brand (OD 4-13/16") and the 6" driven pulley is a new, unbranded recent replacement that is identical in all relevant respects to the original Comet. (I broke the original through stupidity many years ago when my sister got this unit; it's never been operational in the 12-13 years she's had it.)
Here are pictures of the drive pulley, both open and closed (The only reason you see the chain in the one pic is that it's not on its sprocket.):
<P>
<P>
<P>
Some observations/questions about this pulley: 1) It closes nicely when the engine speeds up (no belt on), but it doesn't open back up by itself - you have to push it back after the engine stops. Is it supposed to be like that, or is it supposed to be spring-loaded to open automatically when engine speed decreases?
2) That brass bushing you see in the bottom of the 'V' moves independently of the moving side plate, but never seems to get completely across to the fixed side. Is THAT supposed to be the case?
3) Does it appear to the experts that it's opening as far as it should? I can't get it to open any farther than it is in the pic.
A 1/2"-wide v-belt (Yes, I know that's not the proper belt configuration for these.) will not bottom out in this pulley. Am I correct in thinking that the belt bottoming (and the sides not touching) is necessary for this setup to 'freewheel' so that the engine will idle? If so, what width/length belt does it take and where do I find one? The only Comet belt I've been able to find locally, while it is the 'correct' length according to the chart on the packaging, is 5/8" wide and just won't work at all.
I've been able to ride it around with the 1/2" v-belt on it, by pulling the belt down into the driven pulley enough that the drive pulley can freewheel, then starting the engine and getting it rolling a little while opening the throttle. As soon as the drive pulley opens and contacts the belt, you're off! It goes about like I imagine it should, but when you stop, it stalls the engine. Not a realistic operating procedure!
I'm going to a Super Bowl party as soon as I post this and will not be back on until tomorrow. Thanks in advance for any help! If you have questions, ask away. I have more pics, and I can find out anything you might want to know to clarify things.
