Zinc Plating #1
Mixed up the witch's brew and tried out zinc plating today, as shared by Mr. Pat (thanks!). This is going to be detailed as I've gotten several messages about it. Some general notes here:
If you're using an old phone power supply (like I did), the device is not designed for this purpose and it gets HOT. You are feeding current through two anodes and across a liquid. Give the transformer a chance to cool down between "dips."
If you have a GFI-circuit handy, use it just to be safe.
Solder alligator clips to the leads from the power supply. As Pat noted, much easier and safer.
Use 14AWG wire. Make sure the part to be plated makes good contact with the wire. Keep the sheath on the wire except where it goes into the "brew." What I did was strip in the center of the lead wires and ran a pigtail for the alligator clip.
The brew is 1/2 cup Kosher Salt + 1/2 cup Sugar + 1/2 gallon of vinegar. A large plastic coffee can works well as a vat. Stir and let sit with zinc anodes in "brew" for 3-4 hours.
