I really like the look of engine scoops with the butterfly valves on them. well my briggs 5hp came with two holes drilled in the side of my blower housing so I thought why not make use of them? :shrug:
so I drew up this working drawing on autocad. :thumbsup:
all dimensions are in Decimal Inches.
this is the face of the scoop, the small hole to the left is open for engine idle. the two other holes are for the plates, which are in the below drawing.
The circle on the right is the plate for the first drawing, its 0.01 smaller than the hole so it has some room to move. The drawing on the left is part of the casing to the blower. the start thickness is the same as the thickness of the plate, notice that there's still a tiny bit of thickness on the faceplate. This is so the faceplate can sit at a slight angle inside the shell. the end thickness is 1+1/2 the size of the pipe in the below drawing. this piece will be bent around the faceplate and the pipe to form the shell.
The end pipe for the blower. the idea is to attach a hose (and clamp) to this and the other end to an adapter on the carb.
I know this probably wont give me anymore performance at all, but I just think it will look cool. the butterfly will be opened by the engine suction when its given throttle, and ill have a spring to return it on idle. that's not in the drawing but its also not that hard to set up..
here's a crappy cardboard mockup
Tell me what you think, also IF I do decide to make it, I might have some uhh.. left over materials if anyone is interested :wink::thumbsup:..
