Hello my neighbor asked me if I could take a look at their sons go kart. It ended up having a Briggs 5hp flathead on it. I've never messed with one before but told them I would since it sounded like the Carb just needed to be clean. Before I messed with it it crank on choke and run for 10 seconds then cut off. Took spark plug out it was black. Cleaned it off still did same thing. Gas tank is under the Carb. Got tank off and noticed there is only one bolt holding Carb onto the block. Cleaned the Carb put fresh gas in added another bolt to hold Carb on and now can barley get it to crank. And when it finally did it wanted to take off. Looked like there was gas leaking from where Carb bolts onto block Even though it has a thick gasket. I'm lost and really would appreciate any help.
