First off I have been reading for a couple months but I am a new member and this is my first post. I appreciate the tons of info I have already found but I still have some questions. I am building my first Hemi 212 Predator. I will include a build list of what I plan on doing and then ask the questions I have.
Oil Sensor Delete
Governor Delete
Performance Header
Billet Flywheel
ARC Connecting Rod +.02
Black Mamba Jr. Cam
26lb Valve Springs
Mikuni 22 Carb Kit
Stainless Valves
Titanium Retainers
Chromoly Push Rods
GX160 18cc Head
My questions are,
Is the GX160 18cc head a direct swap if it is unmilled?
Will I have to worry about clearance issues from valves to piston if the piston is flush to the deck?
Do I need different length pushrods?
Can I swap the valves, lifters, retainers and etc from my Hemi Head to the GX160 head?
On the compression ratio chart I found on this forum it says with the piston flush at deck and the 18cc gx160 head I will be at 10.1 compression. Is this correct?
What is the highest compression ratio I can run on 93 octane pump gas?
Thanks!
Oil Sensor Delete
Governor Delete
Performance Header
Billet Flywheel
Black Mamba Jr. Cam
26lb Valve Springs
Mikuni 22 Carb Kit
Stainless Valves
Titanium Retainers
Chromoly Push Rods
GX160 18cc Head
My questions are,
Thanks!
