I have a honda gc160, i don't know if it has oil shut off switch if so where? But the motor does have oil in it but i heard they can be really sensitive. The engine will start and run fine with choke on then once warm whether choke is on or off the engine will start to run rich and spit black gas smoke out the exhaust. If you put the throttle down just a tad bit it'll run for a while longer but it eventually dies and will start right back up then die. I rebuild the carb and checked the fuel pump and they checked out. Any ideas would be great thank you.
