Moto I was not talking about air fuel ratio. I was referring to the ratio of gasoline to Nox coming out of the pills or jets. For the same volume or mass, NOx has more oxygen than air requiring a richer mixture. Now depending on the ratio of the NOx/gas from jets to the volume of normal air/ fuel from the carb requires progressively richer mixtures as the oxygen content rises. I hope I am making sense. I will also state I have never played with this but you thread got me very interested in it so thanks for posting this. Here is a quote from a nitrous site that explains it better than I have so far.
The optimal air/fuel ratio for complete combustion of gasoline is 14.7:1 (commonly referred to as the stoichiometric ratio). However, gasoline engines produce the best power at an air/fuel ratio of 12.5:1-13:1. Because nitrous is more oxygen-rich than air, the chemically correct air/fuel ratio becomes 9.65 parts of nitrous to 1 part of fuel (9.65:1). Additional fuel beyond 9.65:1 should be added to make maximum power and to prevent detonation (an air/fuel ratio of 8.0:1-8.2:1).
