Predator 212cc Parts
Will honda clone parts work with the new predator motors? I noticed they were in different categories on the website and that predator parts are more expensive.
rmm727
Most parts from a 196cc won't work on a Predator.
On the Predator:
  • cams have larger journals (rules out side cover swaps aswell)
  • flywheels are a different taper
  • pistons are bigger
  • lifters are bigger
  • rods are bored bigger on the big end
  • head uses a different valve cover and larger dowel pins
On the Predator:
Thank you
Was curious does anyone carry stock Predator parts? My Dad needs an air filter cover and something else(clip? forgot) having to do with the air filter cover.An exhaust pipe fell on it.
Thanks Tim
I may have those parts I pulled off mine, tell PM me exactly what and ill check when I get home...
Exhaust studs on Predator are not spaced same. I think they are closer together. And push rods are shorter on predator. But this was about a broken exhaust? What the hell happened?:confused:
I am pretty ure the Predator bolt pattern is a little wider, I just used a die grinder and opened up the holes a little bit on mine.
I couldn't remember if it was wider or narrow because I'm Abdulla the Butcher and ran a drill bit thru all my header bolt holes. Maybe I should ask Santa for a dremel. :laugh:
Upgrade
I am trying to upgrade my predator 212cc mainly just the exhaust and air intake, wat r some good parts to put on it? preferably performance or atleast something along that line.
#18
This site has a mother site that sells parts as well
Mini Bike & Go Kart Parts
Personally I find it hard to find some things sometimes?
And at times get no response to questions? Maybe they are still building the site or they are just super busy w/ the season?
#20
And r there lil things I can do to the engine to speed it up, preferably not taking the governor off,or anything that is going to make it over heat quicker
