My predator 212 has so much crank end play that the flywheel fins are hitting the cover bolts. I want to replace the bearings. Does anyone know the size of bearings needed for a first generation non-hemi 212?
https://www.OldMiniBikes.com/Crank-Bearing-ID-_875-OD-_2_048-Width-_500.html
or
https://www.OldMiniBikes.com/Crank-Bearing-ID-_792-OD-2_048-Width-_500.html
or something else?
Also what cam, valve springs and timing key would you recommend for a mild performance boost?
or
or something else?
