So I put a new (old) Tecumseh on my Trail Horse today. I'm a little confused as to what's going on. When I mount the engine and tighten down the bolts to the desired chain tension, everything looks fine. Until I start rolling the bike. FYI - this is a direct drive set up...no j/s. The chain will get super loose, then super tight in a cycle of such. My first thoughts were that the engine was mounted slanted (one side slightly more at an angle than the other)...not the case. I got everything straight, and still doing the same thing. Then I tried lengthening the chain so that I was on a different part of the surface of the engine plate....all the way forward in this case. Still doing it.
Thoughts, experiences with the same???? Anyone....:shrug:
