Since my rear tire is 14 inches tall, I want my gear ratio to be around 7:1 behind the torque converter.
With the 40 tooth sprocket on the wheel and a 12 tooth sprocket on the TC, I have 3.33:1. if I take that same 12 tooth on the TC to a 24 tooth on the jackshaft, then an 11 tooth on the shaft to the 40 on the wheel, I have 7.27:1 behind the converter. That should allow me to tweak the springs on the converter to keep the engine in the 35-3800 RPM range. Wow, that sounds complicated. It'll make sense when I get some pictures.
