Tilly 212?
Mini Bike & Go-Kart Parts
Someone on my YouTube channel just mentioned I should try a Tilly 212 motor on my mud motor. Have any of your tried one of these motors? Do they really hit 10 hp straight out the box governed?
I have a Tillotson 212 that I run on a Trailmaster MB200-2 mini bike. I too, was interested in the 10hp out of the box stock engine. My plan was to just install this engine on the mini bike in stock form and call it a day. NOT! Didn't happen! Here's a link to my thread on the engine and move to a Mikuni carb.
https://oldminibikes.com/forum/inde...kuni-22-mm-or-24-mm-carb.164378/#post-1197279
With all that said, it appears to be a pretty solid engine. ONE IMPORTANT POINT, THE CRANKSHAFT LENGTH ON THE TILLY (LEFT SIDE OF THE ENGINE SIDE COVER TO THE END OF THE CRANKSHAFT) IS ONLY 2 1/4", VERSUS THE HISUN OF 2 3/4" AND THE PREDATOR 212 OF 2 1/2". This caused me some issues with the stock TAV setup as the driver pulley wouldn't fit on the crankshaft, too short. Valve springs (supposed 26#) use auto style retainers, crankshaft is machined well no interference issues with different cams, supposed factory 10,000 RPM flywheel, stainless push rods, and versus the HISUN stock 196cc I would say that everything is a better grade.
Does it feel like a 10hp engine out of the box on my mini bike? NO! However, I may have a serious gearing issue with my mini bike based on weight and running a TAV with 38 tooth rear sprocket. Now that I've done a build and changed out the rear sprocket to 50 tooth only time will tell when I get a chance to test.
thx, fellas. Just got an email from GoPwersports after asking him about using the motor for mud motor work. This was his reply:
"I don’t know about that, I would think the 301 or 420 Predator would be best. its like you said you have to work the heck out of it to achieve the hp wanted."
Yup! No replacement for displacement. Looks like I'll have to save up for a 420!
That's interesting with the crankshaft stub. I wish manufacturers could stop cheaping-out and leave that extra $0.02, 1/2" length of shaft.
You're one of the few forum members who isn't having to deal with physical size characteristics. I still think you should stick a Hyabusa engine on the end of that stick, and show those fish who's boss! :D
toomanytoys
Not sure if 10hp out of the box but mine is stage 1 and it freaking rips! Hits 5500 rpm.
In drag race it runs over my stage 1 predator.
I ordered another one and am in the process of putting it on a bt200x with a tav and stage 1.
I know you are looking for a mud motor but just giving my thoughts on my experience
Being you don't have size restrictions I'd go massive.
SAS289
Not sure where you got 2 3/4" from. Maybe from the stock engine on the Trailmaster? If so that crankshaft is bike specific and not a standard clone crankshaft. I have 3 different clone crankshafts and they are all 2 1/4". Including the 16mm Hisun.
