Vintage Tote Gote 760
I seen this bike in person at a local flea market last summer.. He ain’t kidding when he says it’s been outside for decades.. it was rough to put it nice.. this should be an awesome build!
Here is the engine I plan on using, this guy was planb from last years build... Nice runner I just pulled it apart and checked it over, and rebuilt the Carb. changed out the air cleaner for a 7 hp model and done! 20190101_095945.jpg
Davis
That is a nice motor what does the output shaft look like. The climb away clutch needs to be tight to the motor. If it has a collar you either have to pull the crank and machine it down or cut the motor plate and move the motor over.
I plan on making a custom back plate for the clutch that will allow the complete unit to slide in tight...
