I got a little sidetracked...
I changed seats...
I'm thinking of a color scheme using sun yellow, satin black and bright metallic silver...
I also centered the engine for better balance and footpeg clearance on the right side...
This means I'll have to use a jackshaft, so I made a sketch and I'll machine a pair of adjustable mounts from this plate steel...
Existing mounting plate bracket holes were drilled out to 3/8"...
I'm also working on two intake manifolds to mount a Mikuni VM22 to a 5hp Briggs flathead...one steel, one aluminum...along with a crankcase mod to run an impulse fuel pump.
Pics later...I'm deciding whether to make two just for me or two dozen in case someone else wants one.
