zombiewoof needed a Trail Horse Sissy Bar.
I took on the task, :grind:
Straightened out a Banana Bicycle Sissy and cut off the ends.
Added solid Aluminum rod for strength in the lower bends.
Drilled holes near the top for the cross bars and the rear seat holes.
This bar may be to long at the base, so I have left it for him to cut as needed and drill the other two holes. :hack:
Then I put in the bend at the top as required, it may need more bend. :confused1:
Yet to be discussed..
Made my own cross studs from 3/16" Stainless rod and then threaded them on each end.
Cut 1/2" Stainless tubing for cross rods, fish mouthed the ends and polished.
Installed stainless nuts and star lock washers.
Only Downfall; The two holes where the banana seat would have been mounted on a Bicycle.
The reason why a third cross rod was installed.
:sailor:
Please note; This is the Sissy for the TOP mini bike pictured.
