TWID 2016 OldMiniBikes Build Off Just 4 Fun
Thanks for participating. Looks all new and shiny...should be a good project. I do see an interesting mystery motor in the back corner.....nice mug:thumbsup:
Twid
Thanks everyone! It is a Azusa, I got a couple 8" kits off C-List around thanksgiving. I gave one to my brother and this is a leftover. The motor is a predator 212 non hemi. I had it for another project that I went in a different direction. You never know it might end up with a blockzilla in it. It's going to be a clean fun bike. Tiki Tiki
Twid
Mocked everything up tonight, this weekend I'll get the motor completed and post up what went down.
Twid
My camera took a poop couldn't take pictures this weekend but I did finish my motor.
Pred 212 non hemi
removed gov/ oil sensor and plugged both holes.
Installed ARC con rod/ flywheel
Dyno mod2 cam
18 lb valve springs
Side cover studs thank you kmc3420
Msd plug wire thank you bikeworm
22mm mikuni carb
Painted valve cover and vented with small air filter
Open header
Cheap chain gard
12 T max torque clutch. / -60 t rear sprocket
Autolight race plug
Magnetic oil plug
Big thank you to OND your predator build thread was great help
Also painted my frame an fork set too
Twid
Rear drum was thinking about slamming on front an rear disk tho.
Might not I'd rather put the cash in my MDB.
