engine model number is OH195EA
I've tested the wires and this is what I have : green is engine kill, black is ground,red is hot, and yellow is hot.
My question, I'm not going to run brake lights. Just a small headlight and tail light. Which of the hot wires do I Use? I believe the red has stronger reading than the yellow.
Also I saw the wiring diagram at the beginning of these threads. The 1157 tail light bulb I understand, but what is an A & B headlight?
Will an LED tail light work on these engines? For a headlight I have a hook up spot lamp from a semi truck,will this work? Amps make a difference?
One other question. When the engine idles it 's up and down like it's on the governer. Is this carb or is there an adjustment procedure for the governer?
Any help would be appreciated, Thanks in advance.
Mark
Mark
