well guys , big changes the last minute,,,,,,,:doah:maybe for the good.........:thumbsup:
i had a lighted coil 5hp briggs that i have been sitting on for awhile. so i desided to look into the lighted coil first to see if it was ac or dc current and how much amps it put out. second big problem was if i could swap the 120v electric motor only with a older 12v motor and still use the 120v nose housing so it would still bolt up to my lighted coil engine. lighted system i was going to use was a very small sealed battery with leds bulbs. that would of work just fine. but i wanted to go one more step with the bike and have electric start......:thumbsup:
lighted coil check out good for me and look to be putting out 2 amps. just enough to put a very light change back into the battery while ridding the bike...........
after i modified the starter i did a load test to see what kind of amps it would draw. this way i would have a better ideal on what kind of battery i would need....:thumbsup:
starter peak for the first second or so at 50amps on my gauge and then drop at 18 amps while turning it over.
i found a new battery that was very small and was rated at 70 amps. but right out of the box it checkout at 12.5v and did a amp load test on it and peak at 130amps.......:thumbsup:WOW!
also buy going with this setup i had to tap some holes into the frame the last minuted before priming and painting the bike. i wanted to keep the wires hidden in the frame and there was alot of wires to hide. for example, i wanted the small briggs Solenoid tuck under the seat and the wires not hanging out.
built a battery box that will sit behind the engine.
pickup a very cool 6 plug briggs starter switch that has a kill switch,then lights on and running,or no lights and running.
and yes i am trying to get it done for windber...................
