Hello, I have a Briggs flathead that I would like to convert to gas for a mini bike I have, I had bought this engine and a few other engines and parts from an estate sell. so I don’t really know much about the engine,it looks to be open modified to me but idk. I believe it ran on alky before...
Hello Everyone. I bought this old bike a few months ago, I haven't been able to ride it a whole lot. The problem I am having is that the chain keeps coming off the rear sprocket. Nothing I do seems to rectify this issue. I started with replacing the chain, since the other one broke. This did not...
Hello, I’m building a predator 212 non hemi and need advice on achieving a 10.5 to 1 compression ratio, how much should I shave the head? I haven’t measured how deep the piston is in the hole yet because I already took the whole engine apart and I’m waiting on my ring compressor and other parts...
Good afternoon,
Just reaching out for some help for some probably self-inflicted problems. I have a stock predator 212 bike and stupidly leaned it against something unstable. It fell completely over on the air filter side and was there for probably 30 minutes and a ton of oil ran out the carb...
Hello everyone. I just got this 6.5hp vanguard for a good deal on fb marketplace. I cannot get it to run without spraying starter fluid into the intake. Once I do that, it fires right up, and stays running.
Hello everyone. I have this vintage Briggs and Stratton 3hp engine that I am restoring. I replaced the old breaker points ignition coil, to the modern electronic magneto coil. After I did that, it started right up and ran perfectly. From there, I removed the carb and gas tank, so I could repaint...
Hey everyone, I have been restoring this old Briggs engine for a mini bike project. Before I took it apart to paint it, I replaced the magneto coil, and it fire right up. Once I finished the paint and reassembled it, I tried to start it, and it would not go. I sprayed starter fluid into the...
Hey guys, I recently rebuilt my Hisun 196cc motor and when I run the engine it idles roughly. Here's some specs
18 LB valve springs
PVL Aluminum flywheel with 31 degrees BTDC
Billet con rod
governor removal
BSP-2 cam
Everything else stock
The engine seems to run fine at higher RPM but at idle...
Hey guys, so this is my first time posting on here. I'm currently rebuilding my Hisun motor from my Coleman CT200 and I was wondering if I should get rid of the plastic camshaft gear soon. It just seems very sketchy to me to have a plastic camshaft on the motor.
Here's a list of mods I have...
I've read a few post and searched threads and need to install a pulse line for my fuel pump. Wondering where y'all would drill and tap? Tecumseh uses vacume fuel pump I believe, I also have no experience in this and am learning as I go. Whoo hoo!
The tube coming out of the cover below the...
There's a listing on craigslist listing for a 5hp briggs and stratton and it looks decent the guy said $60 and its mine it starts on starter fluid he said but then dies so its probably a carb issue. Is this a good price and will it be a cheap fix?
So i’ve thrown together a pretty strange setup for my chain tensioner on my minibike. The issue i’m running into however is that the chain is completely destroying the roller wheel. I’ve had on wheel get completely eaten all the way to the bearing and now caused a chain to break. My question is...
Hello! I have found many digital tachometers to fit my minibike, one wire going to ground, the other to the ignition wire, but I would like to figure out how to add an analog one so it looks a bit nicer. Anyone have any insight? Im a bit of a noob but its going on a baja doodlebug with a...
Hey all! Ive got a monster moto 80cc and whenever I pull start it, the engine won’t stay running. I’ve cleaned out the carburetor and I cleaned out the air filter, replaced gas, and replaced oil, yet I still see the same results. I can’t attach a video of the issue. Any help is appreciated!
Hey all, I don’t know if this forum is still active but I have a monster moto 80cc minibike and it has been in storage in the garage over the winter and now, after I drained and replaced the gas and oil it only starts for a couple seconds then the engine stops. When I turn the throttle within...
So after about 2 years of not starting, my preadator 212 ran into another issue, the kill switch doesn’t work, not even the stock on on the engine. My question here is how do i fix this, i am not good with wiring nor do i know how to identify the issue. Any held would be great!
About 2 years ago I bought a mini bike to mess around with and had zero knowledge about them going in. I bought a "Ruttman mini-bike" on the higher priced side as I wanted something in better condition and wouldn't require much maintenance. I've recently have been wanting to give it an upgrade...
