Hello, I’m building a predator 212 non hemi and need advice on achieving a 10.5 to 1 compression ratio, how much should I shave the head? I haven’t measured how deep the piston is in the hole yet because I already took the whole engine apart and I’m waiting on my ring compressor and other parts too come.
HERE’S WHAT I ORDERED
3.308 rod
Billet flywheel
292 nr racing cam
26lbs springs
1.1 champ rockers
.18” mls head gasket
3 stage center exist header pipe
Chinese vm22 carb & manifold (with jet kit)
I will be ordering CM pushrods after I measure and see what size length I need. Also I am planning on porting the head, I just need more tips and advice. Give me your guy’s opinions on the build, if there’s anything I should do or change, also this engine will be going on a mini bike.Thanks
3.308 rod
Billet flywheel
292 nr racing cam
26lbs springs
1.1 champ rockers
