replacement
  1. markus
    Well it is a Lil Indian......
    ....Just not one to get excited about :laugh: Spotted this on craigslist the morning, pull the rope and go, so I drove up and picked it up. not too rigged or butchered. The engine is an H35 at least that what the decal says, but man is it powerful!!! I know they changed the HS40 intake exhaust...
  2. H
    FUJI Go-devil-----fuel valve-petcock broken
    Picked up a nice old go-devil but the fuel hose connection broke off the cast fuel valve. Am looking for a good original or a replacement. Anyone got one?
  3. Iron Honky
    New Ghettoneck rider- no cat hoaders to lool at this post haha
    Well as some of you know I parted ways with my beloved DUCKENSTEIN for my new 1967 wheel horse build. So I needed a replacement. Found it today. Behold the desensitzor( eliminator)
  4. S
    Murray Track 2 replacement mono shock
    Has anyone ever replaced their mono shock? What did you use?
  5. JohnnyTillotson
    Question about wheel bearings
    Looking inside this wheel are the red arrows (and possibly the green, although that could be the outer ring of the bearing) pointing to a sleave or something? I have replacement bearing to install, should I try to save these? They are pretty far gone in any case. What are they?
  6. butch63
    computer down
    computer blew up right after Christmas. finally got a replacement & hooked up. a lot of catch up reading to do:laugh:
  7. dw1973
    52 Dodge B3B truck
    I have an opportunity to trade for this 52 Dodge B3B truck. It runs good and will need body work, brakes and exhaust. Frame is in good shape as is the gas tank. Don't know much about this truck and value. Not having much luck finding replacement fenders, running boards. If anyone can give...
  8. Txpowdercoater
    73 rupp hustler
    I have a guy wanting to trade me one of these (73 rupp hustler). this is all I know, I dont know anything about its condition yet, waiting on photos. Anyways, I need a general idea of what a good one goes for so I can value it properly in the trade deal. Nope, I'm not going to sell it when I get...
  9. H
    Alexander Reynolds Replacement Engine Mount Plates
    Due to popular request we have reproduced the ARCO engine plate. This will fit other custom applications as well. Alexander Reynolds Mini Bike Engine Mounting Plate
  10. K
    Replacement baja doodle bug throttle control
    my stock throttle broke. i need a better throttle. what is the diameter of the handle bars on it
  11. Rat Rod
    Baja MB165 Replacement Carb Issues
    I picked up a used Mini Baja (Warrior) 196cc last week from a guy who's son had ridden it. Apparently it had been sitting for the past year because the gas had really gone bad and it would not start. Got the bike home and cleaned out the tank with carb cleaner and instead of cleaning the...
  12. G
    replacement bushing for 16mm clutch?
    I am looking for a replacement bushing for a 16mm clutch. I can find 5/8 and 3/4, but not 16mm. Anyone?
  13. T
    Can someone recommend me replacement forks (Powerdyne)
    I found some horrible welds on these forks, they cracked very easily. Can someone recommend me a replacement fork? It doesn't have to be Powerdyne nor do they have to have shocks/springs, I just want forks that will work on my Galaxie/Falcon with some strength, integrity. OldMiniBikes? eBay?
  14. B
    Tire Removal and Replacement Rupp Plastic?
    I think my rims are plastic off an early Rupp. Are there any special methods to doing this not to damage the rim
  15. U
    Peerless 133B replacement sprocket?
    First of all I would like to thank all of you who have given me a ton of good info on my project. I have a 1974 Alsport TS110 built by Promark. I am looking for any information on a replacement rear sprocket that bolts to the Peerless 133B axle. Are these sprockets available or is this...
  16. R
    Idea for replacement sprocket roller
    Saw this at a local motorcycle shop. It was $8.00 and has the same bearing ID as the stock DB30 roller. It is not as wide so I don't know if you can run it as is with a shorter bolt or if you will need a different spacer but I think it was worth a try for the price considering what a OEM...
  17. H
    Predator 212 - Cam Replacement
    I'm about to get started on my 212 overhaul, installing a billet flywheel, rod, and heavy springs, but i need to ask the question... Is it recommended to replace the cam as well? I think the non-hemi has a plastic cam wheel. I havent read anything akin to the recommendations that the rod...
  18. lil indian chopper
    replacement windows
    one of my replacement windows crack when i got home today.WTH! 3 yrs old andersons.. picture window then 2 small side windows that open. noticed it today when i got home from work. looks like the cold got to it. cracked from inside... low E class..
  19. K
    Fuel Fitting - must I use the same replacement
    I am tearing down the carb on the Bird Thunderbird I am working on:hammer:, and will need to replace the fuel fitting on the carb. The plastic piece is broken off and the metal tube is still attached:facepalm:. I don't think I should have any issues getting that out, but I was wondering if I had...
  20. charliechaindrve
    GC160 crankshaft replacement
    I recently bought a used powerwasher for 50$, with a honda gc160 engine on it, starts first pull, but the water pump is busted. I had thought that the engine would make a terrific mini bike motor,but Unfortunatly, the crankshaft is way to short for mounting a clutch on. its only about an inch...
