Can you take a photo of your Engine / Muffler / Tank set up?
A bad crank seal could be a big problem when it comes to starting and running.
Your Impulse line ( fuel pump line ) should come off the clutch side of the crank case.
Reason: If the seal is gone, it will not pump fuel ( this way you know you have a problem )
You can check and see if your fuel pump is working just by seeing if fuel is coming out the return line.
( Most carbs have them, some don't )
One way to check if its a carb issue, Remove the fuel line. So now you have no fuel system.
Take a squirt bottle with mixed fuel an squirt a bit in the carb ( nothing too heavy ) It should fire and run for as long as there is fuel.
Now once it is running you should be able to keep it going with a little shot of fuel once every little bit.
Might even get to set your idle if your lucky.
Now try it with your fuel line hooked up.
Also, if your muffler is plugged up ? It can cause problems with starting and running.
I found out that one the hard way. :crying:
