You did not try very hard.
Ask for more help.
Screwing up is easy, just rush things.
Doing it right takes research.
STORE
I have the feeling you are going to screw this right up.
So I would like to suggest you build exactly this...
Others might suggest alternatives and its up to you to research a build so you do not screw it up.....
Get the Momba jr.
A +020 pred rod.
Use a non hemi head, the 18cc Honda is real good, but a milled 27.25 combo to around 18cc is also a good choice.
Get an iron billet flywheel, they are cheap and good enough for you.
Upgrade the valves springs retainers and rockers, stock push rods are fine. ( these are the only points of concern i have because they are unpredictable ).
I really like old style Champion rockers. ( find them used or buy new )
Your header Id should not be larger than .875 and I would like a pipe about 16 to 20 inches long. (longer is better for you, this is simple and cheap preserves torque and breaths well enough for a fun kart or bike )
Set you timing around 25 BTDC as a starting point ( because I know this will not be too much, and there is room for more if needed
A real Honda Ignition coil is nice.
Jetting is a crap shoot I have no suggestions
carbs can be confusing too.
I came up with the idea of running a Tillotson Intake and Tecumseh series 4 carb ( anyone can turn screws and make it work )
What I suggest will work.
Why did I tell you this?
if I come across badly no offense, this thread has been done to death and I think I have made this post more or less the same for the past 5 years
You posted no plan about what you are building.
Variations on this theme have been built by many, its reliable, predictable and easy to tune and drive. ( easy double the power to 14 when tuned right as well )
