ok tonight i drilled out the main jet. holy :censure:!! the front wheel does n ot want to stay down. this is great.
problem though. BTW, this is a predator in a badger 100. before doing anything, the motor would start no problem with full choke. however, i could only move it maybe 25% and it would sputter and die. so i drilled out main jet. works good, but i can only open the choke about 90%. if i open all the way, the motor will not stay running unless i keep blipping the throttle. how do i adjust the predator idle screw? the predator doesnt have a idle jet, right?
thanks chris for all the info you put here.
TTS
