Man we used to use MEK in the refinery by the drum full...we were bathing in that stuff. Then it disappeared because we heard it was bad for you. Now they say it's not all that bad for you. :shrug:
We use Heptane now as the solvent of choice and I hate that stuff...gives me a wicked headache.
I thought it was still on the "bad" list, and we could only get MEK substitute. (Whatever that is)
Riding this thing a bit more, it's fuel starving. Fuel outlet is just about even with the inlet/float bowl top. Shuts down, wait a bit, starts right up.
So what do we do when we get a new carb? We check the float level. However, "I" failed to do that, because I "assumed" it was correct. Why not, both jets were slip marked, so I know it was ran and adjusted. :facepalm:
Now, I will remove the carb, remove the main jet, emulsion tube, screw up the gaskets, deal with red locktite, and hopefully find the float out of adjustment. I should have done this earlier. :hammer:
If it's level, I'll be installing a vacuum fuel pump. Probably should anyway, since it's a hill climber. (and I even painted over the "Satan" moniker)
