Need help finding oem predator 212 part
ok, i tried to call the 800 number on my 212 owners manual, and it says the number is no longer working.
Don't even ask me how I screwed up the return spring on the throttle control. I don't even see it on the assembly diagram. So where can I get it?
Or does anyone else has used something else that worked? The thing returns like a limp noodle the way it is!
Any help would really be great. thanks
[/URL]
since when do those return springs work anyways :shrug:
I always drill a hole on the end of the arm and put a stronger spring attached to wherever is most convenient for me :laugh:
Wow, you guys rock. I'll let you know if dave comes thru. If not, i'll hit one of you other fine Gents up. :thumbsup:
Thanks again.
I do the same and run it to a valve cover bolt , simple and effective ! Harbor Freight sells a spring kit with 200 springs for like $5 ! It aint nothing but a spring ?
