Im looking to build a non hemi predator with RTC-8 head. It's going to be put on a asphalt go kart that will be used for parking lots and maybe on the streets in a subdivision. I would also like to use pump gas. So far I'm thinking:
governor removal
ARC flywheel
308 cam (102 centerline) (I hear this has a wide power range?)
ARC rod std + .020
Hemi flat top piston
26# springs
S/A carb
I dont want to get the compression too high that it will run like crap on pump gas. Any suggestions?
governor removal
ARC flywheel
ARC rod std + .020
26# springs
S/A carb
