Just got back from pickingup the parts from being zinc plated.
Wish the sprocket didnt have the pit marks in it and othetside gouged up from the chain. It will have to be good enough.
I got a couple more things done on the bike. Got rear wheel all together and mounted on bike along with front wheel mounted on bike. Chain tentioner mounted.
I forgot to mention the snaps being put on. I also got the foot pegs and covers put on. Just got front fender put on. I had to add lock nuts to back side the fender threads were kinda iffy for holding fender tight.
I have a question that i have been tossing around in my head. To kill the motor?
Now do i go 100% correct and use the kill tab only on motor or should i also wire in a kill button on the handle bars ?
Rick - I too am with Jim / Delray & Manchester - put the kill switch on for safety sake ! Nothing will ever detract from the quality, care and love you have devoted into this build ......... someone is going to be very very proud to win that bike !
I agree with everybody on that.
I'm in a similar situation building a motor. Does the kill switch plug into
the On/Off switch, or to the wire coming from the coil?
I was thinking the same thing as all of you but just wanted all of your opion on this. Handle bar kill switch will be added. I will wire it now before flywheel goes on.
Just a reminder that donations for the build of this bike are a big help. So even if you only have a couple of bucks it all adds up. Even $10 or if you could do $10 a month for the next 5 months. I try to send a little extra whenever I get parts from Rick to go towards the raffle bike. He is donating a lot of time and expense for this and its a great thing he is doing. So help out if you can.Thanks
Well the motor is rebuilt but it has not been started yet. Maybe tomorrow or the next. I did wire in the kill wire to motor. Once i get it running good i will clean up and paint it.
