I'm in the process of tearing down my lastest mini bike and it seems that everything I try to do, the bike is fighting me on. I had to walk away a few times or the bike would have become a flying projectile.
Where do I start:
>Bike leaks rusty water out of the frame inside my cars trunk.
>Bike scratches bumper of car on the way out of trunk.
>Had to cut throttle cable off of motor because allen screws holding it on to linkage were rusty.
>got the front axle and the punch I was using to tap it out of the wheel and fork somehow stuck inside the wheel wedged against each other. Finally got it unstuck and both axle and punch out but the punch damaged the OEM axle.
>broke off 3 of the 5 bolts holding the front wheel halfs together.
>Tire was rusted to the wheel, had to cut it off with tin snips. Probably have to do the same to the rear wheel if there is a lot of rust. Did I mention that they are the original double indian heads. :facepalm:
>A previous owner used rounded carrige head bolts for replacement hardware at some point in the bikes life. Well they were difficult to take off the handle bars and brake hardware, when you have nothing to put a wrench on. Had to use a pry bar to get enough leverage and pressure on the bolt, to be able back the nuts off. In doing so with the handle bars I accidentally put the other very sharp end of the pry bar through the seat vynil.
>Got 3 of the 4 seat bolts out and had to rip the seat off to get the 4th. Seat was already damaged and I was pissed so at that point I didnt care anymore.
I'm naming this the "Bad Luck Bike Build" :angry:
Here is a pic of the lil turd.
Where do I start:
