I had the day off so I worked on the mini . First thing I did was to get the seat and gas tank mounts on the frame . The tank is mounted in what some might say is backward but it's how it's going to be . The wide part is facing the front and then it tapers back , it's the same as any old school motorcycle . The tank is also rubber mounted . The brake needed a tap welded to the frame to hold it from turning , it also had to be slotted so the wheel can be adjusted . And the main reason is cause the pit cock is in a position that it only works this way , and barely works at that .Also got the rear chain on , needed that so I can figure out the brake foot peddle and lingage . And last but not least I got the foot pegs on and halfway welded .
