Ok here is what I got in it. :thumbsup:
6.5H.P.
CARROLL STREAM MOTOR
ARC Header and Muffler
ARC CNC machined top plate/throttle mechanism
ARC billet air filter adaptor
Choke hold
Mikuni Fuel Pump
Pulse inlet fitting
Angled High Flow Air Filter
Cam = Dyno “CM” Modified - .275 lift at the cam
Intake duration is 236 Exhaust duration is 236
Carb = 615 Blueprinted - Airflow has been significantly increased by opening and reshaping the Venturi using a CNC machine. The choke shaft and butterfly have been removed and the shaft hole has been plugged
Arc Billet Flywheel
Stainless steel valves, stock size & length, lash caps, 26lb springs, aluminum retainers and split keepers, 1.3 ratio rocker arms and chrome moly pushrods
Clutch = Max Torque Shoe style centrifugal drum clutch
Front Engine Sprocket = 18 teeth
Rear End Sprocket = 60 teeth
I don't know what the Horsepower is now, maybe someone can give me an estimate on this. :thumbsup: :biggrin:
