Working on the old 5hp I noticed a ridged circle in the floor of the exhaust port...is this a pressed in valve guide? The intake doesnt have this. Im hoping its pressed in so that I can replace it myself. Its the 1 inch crank chipper engine, model 130212.
Seen these listed in the catalogs but dont think I have ever seen them for real, Optionalal high rise handlebar kit :drool:
Glad the only Rupp I have right now is a built in handlbar version, cause I would imagine the bidding might get crazy on these!!!
Vintage Rupp Mini Bike High Rise...
Hi all,
I have been excited lately getting the Baja up and running. I seem to be close now and I am starting to tackle some of the smaller projects. To start, I designed and printed myself a custom air filter cover for the factory setup on a 6.5hp clone Honda.
I added some text to both...
This is the Pak Jak we are restoring. The fellow I bought it from said it was used by PG&E for remote line checking in Northern CA. I think they modified it by raising the seat and forks 7". Take a look. We like it this way, my son is about 6' 2" and this is much more comfortable. We also did a...
heres a interesting tecumseh lighting coil assembly. three coils.....tied together
with a connector that attaches it to a full wave rectifier regulator. when i saw the photo online
i didnt realize the lower right coil was tied into the setup.
aside from the top coil which is 180 degrees...
What Is It ?
Found at the side of the road with its Free sign ! Helping my Buddy get it running.
Looks like a 7hp TEC from Sears on it but, Not OG to the Kart.
What is it ? Any Ideas ?
Very unique Roll bar, is factory !
The kids want to put one of their 6.5 predator engines on the manco kart but the pto is not long enough so the sprockets can line up. I was looking at one of the pmr adjustable motor mount kit. which holes line up with the engine or the factory mounting plate. I can see how this would work on a...
I've got an early 67 Taco 44. It currently has a later 3.5 horsepower briggs on it that runs reall good. I'd like to go back to an original vintage engine. What came on these bikes from the factory? Thanks for your help.
Going to start parting with some of the paperwork and catalogs from my personal collection....
This lot is a treasure trove for the Stellar fans. There is a promotional brochure which includes an article from Mini Bike Guide magazine with some cool backround info on the company and photos...
If you have any neat factory photos, please post. At one time this country produced and made tons of stuff. Those days are long gone. I'm sure some of your parents and grandparents had some awesome jobs. While I have been going through tons of photos, I have come across some pretty cool...
I've seen it mentioned from time time that side exhaust engines were not used on mini bikes, I in fact believed that up until a few years ago when I was researching a particular bike and was doing more than just quickly scanning over brochures or advertisement that someone had taken the time to...
anyone who owns or has bought a Baja Warrior should immediately Clean the engine tray off,both top and bottom and look for Stress Cracks.
this so called tray is made of out Tinfoil,erm Tin,it is Not welded Fully all around the frame and should be replaced ASAP with something called Steel...
Its been while since I tuned a carburetor, but I think my HF 6.5 is running a little lean. It takes about 15-20 minutes of ride time before it will idle which the choke engaged and the motor just seems to lag a bit.
Can somebody give me a quick 101 on how to tune the factory carb on these...
I have George Barris, as I have been told, that I am trying to collect parts for. It has a motor but I do not think that it is the correct motor for the mini bike. I would love to replace it with the proper motor that should in there. Any help or links would be much apreciated. I am also...
Well, i came across this Bonanza MX add and was Floored by this add when it said they were up against minibikes with 30 HP :eek:. You can see in the ad there is are Rupp right on the butt of that Bonanza MX1510. So my question does anyone know what they did to some of these other bikes to get...
