holes
  1. J
    vent holes in frame?
    I have welded up a lot of deck gates, truck racks etc. Always drill a small hole in the lowest part for moisture to drip out. Seen several metal handrails that didn't have them that formed water inside, froze and swelled up like a balloon to the point of splitting. I do live in Arizona but it is...
  2. B
    Need to fill holes in shroud
    I need to fill a couple 1/4" that were drilled in my engine shroud. What would be the best stuff to use? Bondo? Thanks
  3. Biffmini
    Briggs 3hp crank case cover w/ pto mount holes
    I need one of these to mount cat clutch cover.
  4. Fatboy04
    (2) Cat 300 X
    $400.00 Pay pal or Cash as you load. No shipping, will only hand over to a shipper or you can pick them up in Cedar Rapids, Iowa 6 star caps (3 good 3 so so) 1 clutch cover (holes are bigger than they should be) 4 carlisle tires (indian head so so) 1 kickstand 2 frames 1 motor 1 seat non stock...
  5. L
    Bonanza BC 1100 frame/fork
    I have a Mid peg BC 1100 frame and upper forks (w/tripple tree bolt and new bushings) that I can(and only will) deliver to Windber. Sorry no can load photo. Bad stuff: Missing left mid peg support. Has 4 :1/4" holes in frame some hoser drilled to fit a seat. missing 1 rear fender support...
  6. M
    wtb manco 5' aluminum drive wheel or non drilled bearing wheel
    looking for the 5" aluminum drive wheel with the 6 holes drilled or not.
  7. trinik7597
    predator build
    this has been done a hundred times :laugh: old style predator was a cl find with all the goodies :thumbsup: but the block was crap previous owner had drilled out mounting holes real bad and there was over spray all over the block like the bike was painted with the motor on it and no side cover...
  8. K
    Tecumseh OHH 50 shroud
    I have an OHH 50 I am using on a Bonanza 1300 I would like to find a shroud for it that doesn't have the tank mounting holes can't use the ohh 50tank on this bonanza anyways. It would just be nice to have the shroud that doesn't have the holes cheap or trade my shroud & tank thanks ken
  9. D
    Boonie project.
    I had one of these when I was a kid. Now that my son has a mini bike (azusa kit) that we just recently built I picked this Boonie up from jeep as a roller. Plans are to weld up the added holes in the engine plate. Rear tire flip and a predator with a little work and a Chinese tav. This is a...
  10. Commonrail
    Briggs flat head 5hp tank question.
    Is there any coating you can use to fill up the holes that the rust enhanced in the fuel bowl in the tank?
  11. B
    sprocket woes
    I recently bought a blank sprocket from OldMiniBikes. Had it drilled, but the chain ran from too loose to too tight. I figured the holes were off. I enlarged the holes & made a bit oblong so I could adjust the fit. No matter what I did, the chain stayed too loose or too tight. I finally took the...
  12. Not so mini bike
    Rupp roadster 2 gas tank
    Pretty rough but dosent apper to have any holes. $20 plus the ride no gas cap
  13. Mac
    Bought a Gokart, Need ID
    Been told this kart below is a Rupp, but I'm not sure a Rupp has seat side panels with two holes.
  14. CarPlayLB
    Clutch band brake idea for JBRocks
    So ol' JBRocks attached his clutch brake to a 1/4" bolt which would have led to a failure one sort or another. I suggested he make a bracket to attach to the four holes that surround the PTO...BUT! JB had the side cover without those four holes. That got me to thinking! I sat down first and...
  15. B
    Lil Indian frame holes
    As I look at many lil indian frames I notice the two small holes in the top frame rails close to the neck. Mine has these too. At first I thought maybe someone was going to create a fork stop or something but now realize they came that way. Anyone know what they are for?? Thanks.
  16. bigrob
    DMP Scamper
    I decided that my next project is to build my DMP scamper. It is the same as the first bike my brothers and I had 40 years ago That first bike that got me hooked I picked up a frame a few years back and have gathered a few parts It is an 8" steel wheel bike , I had a rear for it but...
  17. Not so mini bike
    Sale sale sale
    Top 2 seats $20 ea Bottom 2 $25 ea Sebac shocks- $30 pair not stuck but could use new paint. 6" manco whee with Carlisle universal tread tire. Bolt stuck in one of the holes and rim of one bolt hole damaged check photos. Threaded holes on both sides for sprocket...
  18. P
    Acme chopper seat for sale
    I have a new seat that is made to fit an Acme chopper mini bike for sale. All black vinyl. T- nuts match the three holes in Acme seat supports. $60 plus shipping.
  19. daverascal
    hs 40 cover
    does anyone have a clutch side engine cover for a hs40 with only one fill hole? The one I have has 2 holes one in front the other in back. Thanks dave
  20. T
    Broke belt on torque converter...need advice to fix
    I have a Baja (mb165 I believe) mini bike on which I installed a Predator 212 with a Chinese made torque converter from OldMiniBikes Warehouse. The chain rubs a little on the inside of the converter plate so I believe the alignment is off slightly. I installed a new engine mounting plate and drilled...
