kit
  1. M
    Manco Big Cat New Engine Complete Electrical Kit Great Shape
    You are looking at a Manco Big Cat Minibike. The price is $1200.00. It is in Ypsilanti, MI. It is one of the biggest mini bikes made. The tires are 22" tall, 11" wide and are mounted on 8" rims. The tread is very fresh. I replaced the jack shaft and drive sprocket. The chain is also new. The...
  2. S
    hs40-55440c tecumseh carburetor kit
    Hi all, Looking for a carburetor rebuild kit for this engine....can someone please direct me to the part number. Very much appreciated.
  3. D
    Anyone try a builder prepared kit
    I'm looking to make my minibike an all around rocket. I want to go on long/fast cruises around the neighborhood and have some pep getting up and going so I can whoop my friends drag racing. I realize that is two ends of the spectrum. Right now I'm leaning toward a stage 2 kit with a billit...
  4. L
    Tomar stellar 4 clutch, 26mm mikuni + throttle + manifolds, promod front brake kit
    All items are in used condition as you can tell, but all function perfectly. Tomar 2 disc stellar 4 clutch it comes with a 16 Tooth clutch sprocket and engagement it at around 3800, but it can be adjusted by removing the washers on the clutch or tightening or loosening the springs. Genuine...
  5. W
    Briggs Valve Guide Kit
    I need to repair the valve guides on a 5hp briggs flathead but I have never repaired valve guides before and do not have the tooling. It looks like there are several options out there. The most expensive and easiest looking to use is the EZ bore kit. I found it here: Valve Guide...
  6. xr7gt
    Heath kit Boonie bike roller
    Nice straight frame. Have 2 speed jackshaft parts including switch and clutch original Goodyear tires. Fenders look great. $300 plus shipping. Text 951-751-7232
  7. H
    Predator 212cc Throttle Kit recommendation?
    Hi, I am in the process of building my first mini bike. I picked up the Predator 212cc engine to mount to a Bad Dog mini bike frame. I am now trying to decide the best throttle option, and there are a couple of options on OldMiniBikes, but significantly different prices. Does anyone have...
  8. JohnnyTillotson
    NOS Clinton engine kit on ebay
    Anyone else see this ebay item?: 152040741796 The stuff of dreams. Hope he gets on butt ton for it.
  9. S
    Jackshaft kit problem
    I installed the jackshaft kit on my mb80 yesterday. The chains arent too tight but when i crank the bike up theres a grinding noise. Feels like the clutch is trying to engage and the bike dies because the carb isnt being opened. I checked to make sure the crank bolt wasnt too tight. While riding...
  10. deadbug
    air filter and adapter kit cheapest combo?
    I'm looking for a cheap combo for a air filter kit for my 212 hemi . I have looked all over online and want to find the cheapest one including shipping any suggestions would be great
  11. 125ccCrazy
    Briggs 5hp Dyno 107ss billet/welded cam with spring kit
    good used billet welded cam, over $150 new... New dbl spring kit with locks and retainers.. $75 plus ship of $6
  12. JohnnyTillotson
    OldMiniBikes clutch band kit cable stop
    Dies anyone know what size set screw goes into the cable stop bit that comes with the kit? Last two kits i bought there was nothing in it. Wanna get one on the way home.
  13. B
    Jack Shaft kit
    I'm sure it's been asked before but does anyone run a Jack shaft kit on their bike? I was thinking about adding it to my 212 predator engine but I wasn't sure if it would be worth the $$:confused:
  14. markus
    NOS 1968 accessory light kit battery operated
    accessory light kit in original box, still wrapped in newspaper from 1968. You see these on ebay, and thats where I got it recently. I only bought it for the headlight as it was closest to correct that I could find for a build I am working on, but after alot of hunting and research I think I...
  15. G
    Original Doodle bug harbor freight 6.5hp engine conversion kit.
    Anyone still selling the doodle bug conversion kit to put a harbor freight 6.5hp in a doodle bug? (I have the one with the metal fenders) I can get the engine locally at harbor freight. I just need everything else. At one time you could buy a kit on here of everything needed, minus the engine...
  16. Jamie1972
    H50 throttle assembly kit.
    Just curious..... Is there a high need for these things?:shrug: If so......I may make a dozen of the linkage kits...
  17. JohnnyTillotson
    Carb kit nut differences
    Notice a difference between the nut of the old vs new for this carb kit I bought. The one on the left is the new one and the large hole is only on one side and small idle hole directly below it. The original has two large holes across from each other and the small idle hole is about 1/4 around...
  18. B
    OldMiniBikes jet kit
    hi guys, I installed the OldMiniBikes jet kit in my 212 predator, but it was way to rich, I tried both jets, so I put the emulsion tube from the kit and my orig. jet and it seems to run good now. the jets are not marked for size. is this kit for modified engines? I was trying to stop mid range surging.
  19. R
    What do I need to do to my 212 carb? Wont run with choke off, stage 1 kit installed
    This is a Baja Heat with a mechanically stock 212 hemi & TAV-2. I swapped in a 35 jet & an Etube from OMBW, an ARC/RLV exhaust & filter/adapter w/ clutch lever bracket. It won't idle with the choke fully open & part throttle is kind of sputtering. I'm sure I have an idle circuit issue...
  20. T
    Asuza minibike kit issues
    I have a problem with a welded bolt rubbing against the sprocket. The bolt that holds the fork of the brake assembly. Its like its just too long. I was about to shorten it but before I did I wanted to see if anyone else has had this issue. Is there an easier solution that cutting the bolt?
