Measures 4.25x7.25 with the larger cap. fill and outlet are on the same side of tank, has the star embossed in it. New cap with rubber insert has some imperfections around the lip of the threads but cap threads on smooth and appears to seal (bought from another OldMiniBikes member said it seals fine)...
Just bought a replacement air Cleaner with filter but I'm missing the bolt that screws into the carb. This is an older Briggs 2hp engine. It has the straight carb with tank attached. What size bolt is used to hold down air cleaner housing?
Hello new to this forum, I have a few quick questions. I bought a billet rod from ARC and want to install new rings also, well I'm not sure if I have the 1mm or the 1.5 mm thick rings. Then I noticed the low tension rings and wanted to know how thick those are if I can use them in my motor?. I...
Figured i'd post up because i'm having some difficulty. I'm running 6" wheels on my MBX10 with the stock 145/70-6 tires. I've been looking around for a good week or so for larger tires without having to replace the wheels. Checked all the normal places online as well as ebay, craigslist, and...
Just ripped apart a GX160 only to find the head looks exactly the same size as the Predator 212 head I have. I was under the impression the GX160 had either a 14cc or 18cc.
Left is GX head, right Predator
Hi,
First post and first question.
I ordered some new tires and received them today.
The size is 4.10/3.50-6
The new Carlisles only show 4.10-6 and are considerably narrower than my original tires. Which are the original Goodyear tires that are probably from the early 70's.
Should I return...
I'm ready for some more power on my 212 Predator. I was curious of the maximum valve size that could be run with the stock 2.756 bore? In other words how big of a valve can I physically fit using the stock bore? thanks in advance.
Picked it up tonight from a buddy of mine. Anyone have an idea what it is?
My son's is the blue mini, not sure what it is either, I'm assuming an Azusa Kit or plan built.
So I have an Azusa mini bike kit with a Predator 212 engine. I want to upgrade from the 5 inch tire/wheel combo to an 8 inch tire wheel combo. Do I need to buy just the tires and wheels? Will the sprocket and brake drum fit the 8 inch tire wheel combo
Hello,
I want a performance clutch but i don't know what size fits my motor, also any recommendations as to quality and longevity between certain clutches?
Thanks
I could use some advice on choosing some better tires for my Azusa with 6 inch wheels. It has the standard 4.10x250x6 tires that I assume came with the kit when it was new. We live on a dirt/sand road and the bike can get real squirrelly with these little tires on it. What are the tallest tires...
hi does anyone have this to hand? i need taper size and length in millimeters if possible although inches will be ok :) e.g 13mm to 19mm over a 30mm length
cheers
Hey guys im looking for some tires for my Trail Blazer project and found some I like but I dont know much about sizes! The size I found is listed as 90/90-6, 4.1/3.5-6, and 410/350-6. Would these be close to a 145/70-6? I dont want something that will lower the stance drastically. Height and...
