Time for a new progect so I puled out this frame I built a few years ago when I first got my bender. Im using a beauitiful old original 1964 Briggs. Its a tight squeeze on the air filter I might have to spread the frame a hair to keep from wearing on the paint. But im going with a 6" manco in the rear and a 4" in the front. The tires I had kinda determined that but It works. I tossed around the idea of a trike like the taco tri-pointer but the way the back axle mounts are I cant easily build in bearing mounts. I think I have everything to piece together a jackshaft. I ordered a new clutch. I have a few foot pegs to chose from or I may wait and see what I can find at the junkyard. I also need a throttle and brake handle. Im going to have to run a clutch brake because theres no way i can run any sort of brake on the sprocket or hub. The problem with that is theres no 4 bolt pattern to bolt a braket to so ill hae to make one coming off the frame. I have a band brake to use. Im going to make a white seat and grips to match the engine. I have some old vinal from the old seats that were in my Porsche so thats cool. I just hope I saved enough material. Im thinking a light blue on the frame should be cool.
