Howdy.
I need help with my predator. I was trying to move the gov linkage just a little to bump max RPM up just a little. Well in doing so, the linkage came off the gov arm. The gov doesn't appear to have any spring tension on it and neither does the carb throttle. However, when I connect the gov arm back to the post sticking up from the block, the carb wants to be positioned with the throttle open. For the life of me, I don't see how to put this thing back together so that the default position of the throttle is closed unless I add another spring to the carb and pull the throttle closed.
Any suggestions on how to assemble it so the carb stays closed unless I intentionally open it via the throttle?
